Blek
Nov 06, 2017Aspirant
RN 10400 : unable to log to readycloud
Hello all. I try a new topic, nothing I've found had been helpful for now. I got a RN10400, everything was fine till the move of readycloud to mynetgear thing. I think I followed every steps I fou...
- Nov 13, 2017
At end, what works for me :
You need to enable SSH on the NAS (system->settings->services).
You connect to the NAS from a Windows PC using putty, which can be downloaded here: https://www.chiark.greenend.org.uk/~sgtatham/putty/latest.html Enter the IP address of the NAS, and make sure the option for SSH is checked. You'll log in as root, using the NAS admin's password.
On a mac, you use terminal - entering ssh root@nas-ip-address (using the real IP of course). Again, use the NAS admin password.
After that, you enter the command
mv /opt/readycloud/etc/registration.conf /opt/readycloud/etc/registration.conf.bak
That renames the file, it doesn't actually delete it.
Then I reinstall the OS from the boot menu, return to original configuration (admin / password), and then all of a sudden, everything was ok, log to mynetgear account and possibility of readycloud.
That's it :)
Thanx to all for the motivation, and if that could help, it's cool :)
Best regards
Blek
Nov 08, 2017Aspirant
First, Thanx for answering :)
Right now, it's still impossible to log to readycloud or netgear account.
The update has been done on both accohnt and both doesn't work.
To make sure it wasn't about the account, after renaming the file, I also create a new account to test an eventual account malfunction... nothing.
The firmware is the latest (6.9.0).
And no, I can't join my nas to my netgear account, this is the step that does'nt work...
When I activate readycloud, it asks me a mail/password box then a new message i didn't have before. "impossible to connect to readycloud, your Nas may be missconfigured. contact netgear"
And internet and services lights have disappeared on the cloud page.
In local, all works fine, pc and macs can read and manage.
To be continued, looking for these status lights....
JohnCM_S
Nov 08, 2017NETGEAR Employee Retired
Hi Blek,
You may try assigning a static DNS on your NAS. You can use the 8.8.8.8 and 8.8.4.4.
JohnCM_S
NETGEAR Community Team
