ryanasimov
Oct 27, 2014Aspirant
RN102: Changing MTU from 1500 to 9000 & connection problems
I worked on this with ReadyNAS tech support and they were unable to reproduce it. I have a simple network with an Apple Airport Extreme doing the routing and feeding an 8-port Gigabit switch. The swit...
ryanasimov
The 102 is connected to the switch (a Netgear GS108) using the port previously used by the Ultra 2. I've tried the new 102 on each of the 8 ports with the same results I've described above.
I evaluated the 312 but decided the 102 was sufficient, as only 3 people total (and never more than 2 concurrently) use it for small document storage; no streaming or files larger than 10MB. I didn't need the additional network port, HDMI, or eSATA connection.
