ryanasimov
Oct 27, 2014Aspirant
RN102: Changing MTU from 1500 to 9000 & connection problems
I worked on this with ReadyNAS tech support and they were unable to reproduce it. I have a simple network with an Apple Airport Extreme doing the routing and feeding an 8-port Gigabit switch. The swit...
Oct 27, 2014Guru - Experienced User
Did you try readycloud.netgear.com from your local LAN?
