jrmitchell001's avatar
Jan 07, 2017
RN102 Cloud Error: Services Offline (Cannot Attach Device)
Ok, getting fed up with this...   RN102 on a R7000 Nighthawk router, and cannot get the NAS to come up on cloud and access remotely, will only do local   I have searched high and low on this foru...
  • mdgm-ntgr's avatar
    mdgm-ntgr
    Jan 11, 2017
    There were some issues with a configuration file as you last did a factory reset on some very old firmware on this box. I manually fixed this config file. Hopefully that has resolved it. If not further investigation will be required.
ProSupport for Business
