jrmitchell001
Jan 07, 2017Aspirant
RN102 Cloud Error: Services Offline (Cannot Attach Device)
Ok, getting fed up with this... RN102 on a R7000 Nighthawk router, and cannot get the NAS to come up on cloud and access remotely, will only do local I have searched high and low on this foru...
- Jan 11, 2017
There were some issues with a configuration file as you last did a factory reset on some very old firmware on this box. I manually fixed this config file. Hopefully that has resolved it. If not further investigation will be required.
jrmitchell001
Jan 09, 2017Aspirant
Running V 6.6.1. Still have the issue.
mdgm-ntgr
Jan 09, 2017NETGEAR Employee Retired
Can you send in your logs (see the Sending Logs link in my sig)?
- jrmitchell001Jan 09, 2017Aspirant
Logs sent. Hope you see something I don't, because there are no errors or warnings that I can tell. Thanks.
- mdgm-ntgrJan 11, 2017NETGEAR Employee Retired
- jrmitchell001Jan 28, 2017Aspirant
Well after a couple weeks I'm happy to report that the manual fixes mdgm made have been working. Still not sure how or why this was such a problem, and hopefully the NETGEAR team can provide an automated fix in lieu of a manual one, but in the mean time, if anyone finds themselves having fits with services being unavailable, and is a novice home network techie, the fix may be beyond your expertise, and will want to contact the team here.
Thanks again for the help mdgm, much appreciated.
Jason
Suffolk, VA
