Popsicle
Oct 24, 2016Aspirant
RN102 currently you have no registered devices
Hi Guys, My readycloud PC client tells me "currently you have no registered devices" even though it was working before. It also throws the following error: What should I do to fix my c...
- Retired_MemberOct 24, 2016
Hello Popsicle
looks like something in your ReadyCLOUD client is broken,please uninstall/install it again from following link
Windows version
http://readycloud.netgear.com/client/install/Ready
CloudSetup.exe Mac version
CLOUD.pkg Please make sure that there is no update package in users folder.
On MAC:check and remove file / Users/[logged in user]/Library/Application Support/ReadyCLOUD/ReadyCLOUD.pkg.version
On windows:check and remove file C:\Users\[logged in]\AppData\Local\Temp\ReadyCloudSetup.exe
Popsicle
Nov 05, 2016Aspirant
Hi Guys,
Thanks for all the helpfull feedback, I really appreciate it!
Reinstalling did the trick for now.
FramerV
Nov 05, 2016NETGEAR Employee Retired
Hi Popsicle,
If your issue is now resolved, we encourage you to mark the appropriate reply as the “Accept as Solution” or post what resolved it and mark it as solution so others can be confident in benefiting from the solution.
The Netgear community looks forward to hearing from you and being a helpful resource in the future!
