montybiggleswor
Apr 23, 2020Aspirant
RN10200 Not powering up - only sign of life is the Ethernet port LED flashes - is it dead?
I noticed today that the LED was off on our RN10200, I tried to power it back on but nothing happes.
No lights, no fans, no noise, nothing!
I tested the PSU and that's still outputting 12v.
We use this as an off site backup for our RN104 so it could have been dead for a while.
I don't know what the sofware version was but I believe I had auto update on and generally I access it every 6 months to check it's okay and if it was out of date I would have updated it then.
I tried to power it up with the hard discs removed (2 x 3TB WD Reds FWIW) in case they were causing it to shutdown but no luck there either!
I have tried the reset button too but no luck.
The only thing that shows any life is when I plug the Ethernet cable in, the green LED flashes.
Any ideas of what we can try or is this the end?
I checked and we bought the NAS in November 2015 so it's only just coming up to 5 years old, I'd have expected it to last a lot longer!
Thanks in advance!
Yes, the NIC and power-on circuit draw power even when the NAS is "off". The +12V is internally dropped down to the necessary voltages, including the standby voltage those items use. From your list of symptoms and tests run, I think it most likely something in that power circuit is the problem. Big caps would be a place to start.
Unfortunately, Netgear does not make schematics available, so troubleshooting is an adventure. Good luck.
- Marc_VNETGEAR Employee Retired
Have you checked with RAIDar if it's still being detected? Also when you tried booting it without the drives. If it's showing that the NIC LED is lit it might still be detected by RAIDar. Have you seen if the Front LEDs are lit as well? If it is detected without the drives, it is possible that there's an issue with the drive or OS.
If RAIDar shows it's booting but does not completely boot normally, maybe you can try doing USB Recovery. Otherwise, if all else has been done and still not getting detected by RAIDar. It may be possible that there's an issue on the Hardware.
HTH
- montybigglesworAspirant
Hi,
Sorry, I should have said; both of the front LEDs are dead too.
I just tried the RAIDAR app and it can only find my RN104.
I guess that means the HW is knackered?
I just popped the bonnet, disconnected the fan and ran it from my bench PSU and the fan span up fine drawing 200mA so the fan sounds fine.
I then fed 12V onto the PCB where the power jack goes in and the NAS draws 125mA so there's something still alive in there.
I then removed the main PCB from the RN102, which disconnects it from the Ethernet card at the back - after this the current dropped down to 20mA so I am assuming it's the Ethernet board drawing the current.
I just went in a bit further on the main PCB;
There's a PSU circuit just below the SKhynix Flash IC which is outputting 3.3v - this appears to be the only active PSU on the board.
None of the other large power inductors have any signal on them, whether these should be running I don't know.
I spotted a big electrolytic capacitor at the bottom of the PCB near the connector that goes to the hard drives. This appears to be the output of a the largest switching PSU- based on an RT8105 IC and a 4228GM FET. The RT8105 has an enble pin (pin 7) which is low thus disabling it.
I am assuming something else on the PCB is commanding it to shutdown but without a schematic I can't find what it is.
- SandsharkSensei
