SteadfastElk
Oct 07, 2014Aspirant
RN104 - Cloud Functionality and Apps
Happy with a new RN104. Currently two area's of interest: - It looks like the cloud functionality is a little buggy. According to support, this may be related to with current Netgear server upgrad...
- Dec 08, 2015
JennC wrote:Hello SteadfastElk,The share permission settings for ReadyCloud users is done on ReadyCloud URL and not in the admin page. You have to log in as the main ReadyCloud account. When you get to the admin page of the NAS and go to Cloud then click Settings button of ReadyCloud, this will show you the main ReadyCloud account that has the authority to set permissions over ReadyCloud URL. Take note of the ReadyCloud account and log in to readycloud.netgear.com using that account and this should show you the the 3 tabs, Home, Manage and Discover where you will be able to see all invited users under Manage. You will not see the ReadyCloud main account under Manage tab because it is already the main account and you cannot change its settings here, since it is like an admin account for access the NAS via ReadyCloud it has access to all shares.When you log in to the URL using one of the invited users, it won't have anything about the same NAS under manage tab because it is not the main account and just an invited user, unless this invited user has an access to another NAS where this same account is the main one. The discover tab is for the ReadyCloud URL to detect if there is a NAS on the network where the user is located.I hope this helps.Regards,Hi JennC,
This sure helps a lot, because it confirms my understanding of how these things work.
One issue is: I'd like to restrict access to all shares from outside the home to read only access. You're saying this can't be done for the Cloud Admin user, so I'll have to live with that. Apparently this is designed behavior.
Thanks very much for all your feedback. I'll consider this the solution.
BrianL2
Dec 06, 2015NETGEAR Employee Retired
Hi SteadfastElk,
Can you confirm if you are still having a problem creating an account through email invite? or giving a registered ReadyCLOUD ID with Read/Write access?
I look forward to your response.
Kind regards,
BrianL
NETGEAR Community Team
SteadfastElk
Dec 06, 2015Aspirant
BrianL2 wrote:Hi SteadfastElk,
Kind regards,
BrianL
Hi BrianL,
Thanks. It seems to work for completely new invited users.
I can't change rights for the only account I haven't removed, which is my Readycloud admin accouont.
In the NAS web admin panel I can't change the rights I assigned earlier, as I believe should be the case for cloud users.
In the Readycloud portal I click "Share" and then "Full folder access" and "Next". The usere doesn't even show up in the "Shared folder options screen, and it's also otherwise empty, so I can do nothing there either,
- BrianL2Dec 07, 2015NETGEAR Employee Retired
Hi SteadfastElk,
Thanks for providing feedback. I can confirm that setting permission works on my end under the Manage tab > Shared Folders > Select the Gear or Settings icon under the registered ReadyCLOUD ID. If this still doesn't work on your end, try disabling/reenabling ReadyCLOUD service under the Cloud tab and add DNS 8.8.8.8 on the active NIC.
Hope this helps!
Kind regards,
BrianL
NETGEAR Community Team- SteadfastElkDec 07, 2015Aspirant
Hi BrianL,
Cloud user:
I can administrate cloud users from the Manage tab in Readycloud. When I go to my NAS locally, I see the rights given to the user.
However, When I log In to Readycloud with this cloud user, the NAS shows in the discover tab, but the other two tabs are empty.
Admin Cloud user:
When in Readycloud with this user, I see the shares etc in the Home tab, the cloud user in the Manage tab and the NAS in the Discover Tab.
However, I don't see the Admin cloud user in the Manage tab.
As you suggested, I disabled and enabled the Readycloud service, and changed the DNS on the active NIC.
This does not help in anyway. Basically, the situation is as before.
Hi SteadfastElk,
Does this happen with different or other invited ReadyCLOUD user ID? With regard to the admin user, It is normal for the ReadyCLOUD user ID not to show up in the manage tab.
Kind regards,
BrianL
