daelomin
Dec 09, 2019Aspirant
RN104 and RN314: out of warranty? ReadyCloud?
Dear community, I am managing 2 ReadyNAS for my enterprise. Turns out they are out of warranty and I don't seem to be able to access them through ReadyCloud. Does anyone know if I should ...
Dec 09, 2019Guru - Experienced User
daelomin wrote:
ps: What I really want to do is synchronize both NAS that are in two separate locations...
The 314 > 104 is typically the sync I need for all shares.
rsync over ssh is another alternative to the ReadyCloud VPN - though you would need to forward a port in router at the RN104's location to the NAS. If you also want to restore, you'd need forward a port in the RN314's router too.
Does anyone know if I should be able to or I need to pay some kind of subscription to some service?
They are supported, and there is no subscription needed. What firmware are you running on the NAS?
- Aug 19, 2019Retired_Member
