Retired_Member
Aug 19, 2019RN314 Readycloud
I have I laptop running Windows 7 Pro 64 bit and a Desktop with the same Operating system on my gigabit Network. The laptop logs into Readycloud with ease but the Desktop Readycloud App (latest) reinstalled a few times has these weird names and will not let me login and keeps sending me around the same screens. I've included a Screen shot for referance. I'm baffled !!!
- Retired_Member
- bedlam1Prodigy
You could try installing Java SE Runtime Environment 8u181 this fixed this issue for me.(this is in addition to "regular" Java)
- Retired_Member
Thank you for that, Ive installed that Java Update, unistalled Readycloud, run a Registry cleaner then reinstalled Readycloud but sadly its still the same.
Regards Simon
- IcewaterhotNETGEAR Employee Retired
Hello ispy1,
You can look at this, it should be the same problem, install Microsoft support package, It can solve this problem.
- Retired_Member
THank you, I tried downloadind both packages but got the messge " Not compatable with your sysem "
- SandsharkSensei
You downloaded the 64-bit package from https://support.microsoft.com/en-us/help/3154518/support-for-tls-system-default-versions-included-in-the-net-framework and it failed to install on your Win7 machine? Are you absolutely certain you have a 64-bit SP1 machine and .NET framework 3.5.1 is installed?
It sounds to me like you have an issue with Microsoft, not Netgear. You cannot blame Netgear for using a more updated security protocol than your outdated Windows 7 machine uses by default, especially when Microsoft has (supposedly) provided a solution.
And, you are wrong that the programmers never supply answers here. It isn't often, but they have.
You are also wrong that the average NAS user sees it as anything but an appliance. Reading through some of the messages on this board will prove that to you. Many problem descriptions are not very technnically complete, and the poster has to be instructed on how to get the necessary information so that the cause of the problem can be determined.
Hello Retired_Member ,
Can you work fine after install this Support package?
Hello Fingerstoo ,
Can you provide the version of your windows10 home?
I tried it on my window10 home 1903, there is no such problem.- Retired_MemberI tried to install the 32 bit package but got the message "not compatability with your system" may do a system restore tonight.
Hi Fingerstoo,
I saw your screenshot, the same as my windows Home version, so it is very strange, you can try to install readycloud 1.16 version, then overwrite the installation version 1.17, try to see if this can be used. Please download and try again.
https://www.dropbox.com/sh/4dlbf9yrinzgj8q/AABOk2OnGmYMqiLgBxiGQ2__a?dl=0
icewaterhot
And here is reinstalled version 1.17 running! Or not properly?
Just out of interest why is the file size of ReadyCloud v1.16 is 42,909KB, whereas the latest version is 9,257KB? Netgear has been radically updating it or cutting something out!
You see the old version had the same problem!
Fingerstoo
I mean your other 3 Windows 10 PCs are also bang up to date and run ReadyCloud perfectly well, But this PC is such this issue, what will be different, This is what we should look for. I have several customers running very well on window 10, so it seems that this issue is not a common issue. Is it possible to reinstall the system or reinstall Microsoft support software?
