daelomin
Dec 09, 2019Aspirant
RN104 and RN314: out of warranty? ReadyCloud?
Dear community, I am managing 2 ReadyNAS for my enterprise. Turns out they are out of warranty and I don't seem to be able to access them through ReadyCloud. Does anyone know if I should ...
Marc_V
Dec 09, 2019NETGEAR Employee Retired
ReadyCloud is free to use service and supported on your OS 6 devices (RN314 nd RN104) but I don't think syncing the RN314 to RN104 is possible with ReadyCloud or atleast would be the best way to do that.
I agree with StephenB of using alternative methods like Rsync over SSH. ReadyNAS Replicate is one good option before, unfortunately it is now EOL.
If you are trying to Sync a Windows Folder to both NAS then ReadyCloud is a good option with the use of ReadyCloud Client App for Windows or Mobile.
You need to make sure both NAS you have are joined to ReadyCloud and also make sure that both Services and Internet are enabled under the Cloud tab.
Leaving and Rejoining them might do the trick on getting access thru ReadyCloud. Also, your Firmware is best to be updated to the latest.
HTH
Regards
Dec 10, 2019Guru - Experienced User
If your firmware is older than 6.5.x, it won't work with the current ReadyCloud. There would also be an account migration needed ( https://kb.netgear.com/30671/ReadyCLOUD-to-MyNETGEAR-Single-Sign-On-FAQ ).
Note that you might need to update the RN104 in stages. If it is older than 6.2.5, then the first stage is to update it manually to that. Then update to 6.5.2, and finally to 6.10.2.
- Aug 19, 2019Anonymous
