StephensHomes
Dec 19, 2016Aspirant
RN212 Admin Password
Upgraded to Firmware 6.6.0 can't access Admin Page. Cleared Cache. Get Message "Your connection to this site is not private". When I select "Cancel" I get message "Sorry, password recovery has not be...
- Dec 20, 2016
StephensHomes wrote:
It returns me to this same screen. Blank Page with Pop-up Login Box.
It will do that if the password is incorrect (and it won't tell you what the problem is).
You might need to try an OS re-install from the boot menu. That resets the network configuration to use DHCP and also resets the admin password to password
Instructions are on page 53-54 here: http://www.downloads.netgear.com/files/GDC/READYNAS-100/ReadyNAS_%20OS6_Desktop_HM_EN.pdf
Be careful not do to a factory default, that will destroy your data.
