SummitBuildTeam
Dec 18, 2019Follower
RN21400 cannot manage through Readycloud PC Chrome
Hello, Cannot log in into Admin page in Readycloud: Home tab shows "Currently you have no registered or shared devices Manage tab shows "Currently you have no registered devices Discover tab ...
Sandshark
Dec 18, 2019Sensei
Any chance you inadvertently did an OS re-install and the admin password is back to the default of password? Almost everything else would be retained if you did.
JohnCM_S
Dec 19, 2019NETGEAR Employee Retired
Hi SummitBuildTeam,
Welcome to the Community!
Is ReadyCLOUD enabled on the NAS? You may check by logging in to the local admin page (Username is admin and the default password is password) , then go to the Cloud tab.
On Cloud tab, check if Internet and Service have green check marks. Please check also if the ReadyCLOUD ON-OFF slider is selected to ON.
