icyvran
Jan 09, 2018Tutor
Secure connection to http://readycloud.netgear.com HTTPS
Hi,
Could Netgear please secure the http://readycloud.netgear.com website with a persistent HTTPS connection?. Right now the secure connection is established only while entering the username and password, after that is HTTP only.
Icy
- Marc_VNETGEAR Employee Retired
Hi icyvran
The ReadyCloud portal actually runs on HTTPS, all connections from apps, portal and back-end access are on HTTPS.
The reason actually that we see HTTP on the portal is for the NETGEAR Home routers where they also connect to ReadyCloud however, with their specifications they usually are having a hard time maintaining HTTPS connection due to certificates being updated from time to time. So seeing the portal on HTTP is just actually for the routers to be able to use its feature but ensuring back-end and other access is secured using HTTPS and VPN connections.
Hope this helps!
Regards
Hi icyvran
We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved, we encourage you to mark the appropriate reply as the “Accept as Solution” or post what resolved it and mark it as solution so others can be confident in benefiting from the solution.
The Netgear community looks forward to hearing from you and being a helpful resource in the future!
