koolfrank87
Dec 29, 2015Apprentice
silent install - ReadyCloudSetup.exe
Can anyone provide me with command line support for the ReadyCloudSetup.exe application? I would like to install this silently or with no user interaction but have had no luck with getting the switc...
JennC
Jan 21, 2016NETGEAR Employee Retired
Hello koolfrank87,
Which ReadyNAS unit are you using?
ReadyNAS OS6 has ReadyCloud built-in. The legacy units cannot use ReadyCloud since they are using OS4 (OS5 for the Duov2 and NV+v2), though some users successfully loaded OS on them.
koolfrank87
Jan 21, 2016Apprentice
I have the 316 but my question is directed at the Window application, not the physical box.
