NWWA
Jun 01, 2016Tutor
Since upgrading to Readycloud v1.12 and FW 6.5 I cannot sync folders to my PC.
I have migrated my Readycloud account to the myNetgear account, and updated the interface and the system FW. I can access the folders and read and write, but the sync funtion no longer works. Als...
JennC
Jun 02, 2016NETGEAR Employee Retired
Hello NWWA,
Welcome to the community!
Did you enter myNetgear account (email address format) and its password when signing in?
- NWWAJun 02, 2016Tutor
Yes, I migrated my account successfully. I used the email and password associated with my Readycloud account and upgraded to mynetgear account. I received an onscreen message that the migration was succesful.
Yet when I attempt to sync the folders to my PC I get a message "offline (readycloud is not available).
Why should this matter, I am syncing to my PC not a cloud account?
- JennCJun 03, 2016NETGEAR Employee Retired
Hello NWWA,
Are you on the network where the NAS is? Please also try going to the admin page, get to Cloud tab then click Settings for ReadyCloud, make sure Use Proxy settings is not marked then click Security, make sure Encryption is enabled.
- NWWAJun 03, 2016Tutor
Hello Jenn - Yes, I am on the same wired network where the NAS drive is located.
I have checked the ReadyCloud settings and the Use Proxy Server is not checked and all the fields are blank. Under the security tab, the encyption is checked, and the specify port incoming connections is unchecked.
