NWWA
Jun 01, 2016Tutor
Since upgrading to Readycloud v1.12 and FW 6.5 I cannot sync folders to my PC.
I have migrated my Readycloud account to the myNetgear account, and updated the interface and the system FW. I can access the folders and read and write, but the sync funtion no longer works. Als...
Wicky_W
Nov 05, 2016Tutor
In addition to my preceding post I need to clearify the "upload"-sync-problem; it occurs in another way then the "download"-sync problem. The following error-message is shown as a floating window as well in Windows Systems as in Mac OS...
An error occured during synchronization
Failed to upload file: <filename>, reason: Service Unavailable
FramerV
Nov 06, 2016NETGEAR Employee Retired
Hi Wicky_W,
Might be also best if you do contact support. I checked your account with us and it shows that you still have free support until January 7, 2017.
