dschwartzer's avatar
dschwartzer
Luminary
Jul 06, 2016
Sync Home Folder in ReadyCloud Desktop App
I have a ReadyNAS 202 running OS 6.5.1 and am using the ReadyCloud Desktop Client version 1.3 for OS X (Mac).  I have created a folder in my private Home Directory that I would like to sync to my Mac but when I look at the Desktop Client, I do not see the Home folder and obvisously, not the subfolders in the Home folder.
If I log in to ReadyCloud via the Web I see the Home folder and the subfolders in it.
The ID I am using is the Administrator ID I created when I set up the ReadyNAS.
I'm thinking there has to be a way to see the Home Folder in the ReadyNAS Client.  Am I missing something?
Thanks,
David
  • StephenB's avatar
    Did you create a folder in home manually?  You shouldn't have.
    The folders in home are created by the system for each user account.  Only the folder named XYZ is visible to user XYZ, and home itself isn't visible (though of course the admin user sees both home itself and all folders in it).
    Similarly you shouldn't add folders to the data volume, instead you should create shares on from the admin web ui.
    • dschwartzer's avatar
      dschwartzer
      Luminary
      Stephen:
      Thanks for your prompt reply.
      I did not create my own home folder.  It was created by the system the first time I signed in to ReadyCloud using the email address I used to set up my master MyNetgear / ReadyCloud account. I see the Home folder in the ReadyCloud web access and in the Admin Web interface but not in the desktop client.
      The subfolder I created was created in my Home folder using the ReadyCloud Web site.  Isn't taht acceptable given that a reuylar user would not have access to the Admin UI?
      David
      • StephenB's avatar
        Thx for clarifying.  I thought you might have accessed \\nasname\data\home and as administrator and created a folder there - which is possible, but not a good idea.
        Yes that is perfectly fine.
        If the desktop client is using the same user credentials, then you should be seeing the home folder (and its subfolders) there.
  • Angelos:
    This appears to be a known issue and will be addressed in a future ReadyCloud Desktop app update.
    In the interim, if you want to set up a private sync folder you can try what I did.
    I created a new share on the ReadyNAS and provided access to only my ReadyCloud ID. I was then able to sync that folder to my (Mac) desktop.
    For now that does what I need but I hope Netgear fixes the desktop app soon.
    Hope that helps.
    David
ProSupport for Business
