Zero_G_
Aug 26, 2018Aspirant
Synchronisation failed for some files
Hey
I use ReadyCLOUD for backing up some important folders. Which are used in Visual Studio for developing.
I am a lot away from home, so this is, why I need the ReadyCLOUD function. But it i...
Retired_Member
Aug 26, 2018Hello zero_g
Thanks for reporting issue!I've forwarded ReadyCLOUD hidden file sync issue to ReadyCLOUD dev team,I will keep you updated when the issue is resolved.
- Zero_G_Oct 01, 2018Aspirant
Hey
It is already 1 1/2 month later, after Retired_Member told me to get in contact with the developer team.
Are there any updates about this?
As I wrote in my first statement, I need it so I can work save on my projects.
I spend a lot of money to have this feature and a good hardware.
In my opionon, this issue has really priority.
THX for any response
- Retired_MemberOct 09, 2018
Hi Zero_G
sorry for the late response!ReadyCLOUD dev is still working on this issue,I will keep you informed when the new ReadyCLOUD application is released.
