GaryW4412
Aug 26, 2020Aspirant
time machine password reset
Hi i cannot seem to be able to change the passwords for users or time machine even though i am logged in as admin. Can anyone help? Thanks in advance
Aug 27, 2020Guru - Experienced User
Can you tell us what NAS you have, and what firmware it is running?
- GaryW4412Sep 03, 2020Aspirant
Hi Stephen
Thank you for helping im not sure what Firmware it is running on the overview page it says version 6.10.3
Regards
Gary
Sorry forgot to say its a ReadyNAS 102
- StephenBSep 04, 2020Guru - Experienced User
Are you using Active Directory or local NAS accounts?
If you are using local NAS accounts, what happens when you go to the accounts page in the web ui, select the user, the choose settings, and change the user's password?
Though I don't use Time Machine, my understanding of the setup is that it simply uses the user's account credentials.
- GaryW4412Sep 07, 2020Aspirant
Hi Stephen B
I tried going into Users but it will not let me change the users paqssword?
I can change the Admin password though?
