GaryW4412
Aug 26, 2020Aspirant
time machine password reset
Hi i cannot seem to be able to change the passwords for users or time machine even though i am logged in as admin. Can anyone help? Thanks in advance
GaryW4412
Sep 03, 2020Aspirant
Sorry forgot to say its a ReadyNAS 102
Sep 04, 2020Guru - Experienced User
Are you using Active Directory or local NAS accounts?
If you are using local NAS accounts, what happens when you go to the accounts page in the web ui, select the user, the choose settings, and change the user's password?
Though I don't use Time Machine, my understanding of the setup is that it simply uses the user's account credentials.
- GaryW4412Sep 07, 2020Aspirant
Hi Stephen B
I tried going into Users but it will not let me change the users paqssword?
I can change the Admin password though?
- StephenBSep 07, 2020Guru - Experienced User
GaryW4412 wrote:
I tried going into Users but it will not let me change the users password?
Are you saying that
- you can't find the setting?
- that it is grayed out?
- that you get an error when you reset it?
When i go into accounts i open up the user account and then when i try to cahnge the password it does not save it and reverts back to an olkd password i cannot remembeer
