Tommy_Lee
Jul 18, 2016Aspirant
Trouble downloading with remote access
Hi All,
I have a machine which is sharing remotely with only a few users but found frustrated because of the file we can download from it.
It does not happen to all files but sometimes a 20KB Excel file will turn out with lines of XML inside, or a 2MB PDF will be 200KB downloaded and unable to read. But if I am viewing all the files locally at the machine all is fine.
My question is, are there any restriction, in particular on sizes and types, when files are stored in ReadyNAS? If someone could help solving this will be much appreciated.
Cheers,
Tommy
- jacuerroAspirant
It looks similar to problem we are describing in this topic:
- BrianL2NETGEAR Employee Retired
Hi Tommy_Lee,
Welcome to the community!
Were these files shared via web link or you are just downloading them on the web portal or ReadyCLOUD mobile/desktop apps?
Kind regards,
BrianL
NETGEAR Community Team- Tommy_LeeAspirant
Hi Brian,
I hopped over to another topic mentioned and tried installing the driver from the previous version. It seems fine now since last week.
Much appreciated for the input.
- AnonymousIt looks like problem solved in OS 6.6.0.
I installed yesterday and links work.
