Blues11
Feb 06, 2018Luminary
Unable to sign in to ReadyCLOUD
I have not used ReadyCLOUD in quite some months. I tried it just now (from Starbucks) and on the page with the window labeled "Sign in with MyNETGEAR Account" I enter my email address and Password, b...
JohnCM_S
Feb 07, 2018NETGEAR Employee Retired
Hi Blues11,
can you try logging in to https://my.netgear.com and see if you are able to login? If you are still not able to login, try changing the password on that site. Please check if you are able to login to the Readycloud portal afterwards.
JohnCM_S
NETGEAR Community Team
JohnCM_S
Hi Blues11,
It is possible that your Readycloud account is not yet migrated to a MyNETGEAR account. You may try the steps provided on this link and check if you will be able to login to Readycloud afterwards.
JohnCM_S
- JohnCM_SFeb 10, 2018NETGEAR Employee Retired
Hi Blues11,
We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved, we encourage you to mark the appropriate reply as the “Accept as Solution” or post what resolved it and mark it as solution so others can be confident in benefiting from the solution.
The Netgear community looks forward to hearing from you and being a helpful resource in the future!
Regards,JohnCM_S
NETGEAR Community Team- Blues11Feb 13, 2018Luminary
I wish there were a solution to this problem. I hope you can help.
When I enter my previously set-up readycloud.netgear.com account email and password, I get both the email address's and the password's displayed in red.
How do I fix this? When I try to delete the account to start fresh, I'm told I can only do this in ReadyCloud, but when I go into ReadyCloud I can't log in.
Even when I log in as the admin it doesn't fix anything.
Again, how do I fix this?
- JohnCM_SFeb 13, 2018NETGEAR Employee Retired
Hi Blues11,
NETGEAR actually uses a single sign-on for the MyNETGEAR and Readycloud. Are you also not able to login using your MyNETGEAR credentials?
JohnCM_S
