DannyBlah's avatar
DannyBlah
Uploading iPhone Media Error
I am having a problem uploading media (photos) from my iPhone to my NAS.
I have a ReadyCloud account and I have created a folder within my ReadyCloud account home folder, no problem. I have then set the iPhone settings to send the media to the ReadyCloud account and the created folder, again no problem. However, when I access the iPhone ReadyCloud app to sync, I get an access denied error and the app keeps trying. I have found that if I create a folder outside of my ReadyCloud account, ie public folder it works. It would suggest there is a permissions settings issue, but I can't see how to amend this within the ReadyCloud account. Any ideas assuming I've made this clear enough, please.
  • Have you tried this with the new ReadyCloud (running 6.5 software on the NAS)?
    You're forced to migrate to the new stuff now anyway, so you should begin by confirming that the problem still occurs.
    • StephenB's avatar
      • DannyBlah's avatar
        DannyBlah
        Yes, StephenB. I have just updated and it fixed this issue. I renamed the folder concerned in my new migrated account, then changed it back to a name I wanted and works as I want to.
        Hopefully this may be of benefit to someone else with same query too.
ProSupport for Business
