civean
Sep 14, 2017Aspirant
VPN Disconnected, Leaf Network connection problem (Again)
Hi,
since 3 days we have started to get some very familar VPN disconnected problems when trying to connect via VPN and the readycloud desktop app. The last 4 times this happened, it turned out to be a problem with a server on the Netgear side - is this again the problem? Can you fix it?
It seems the Leaf Network adapter gets no connection, even though an IP is attained - see picture.
Thank you for a quick resolution,
Christer M
