davesumm
Jan 29, 2017Luminary
VPN Disconnected
Hi, all Is there any new known problem with readycloud? I'm struggling to connect to 2 different NAS systems remotely from my work PCs (2 different PCs) I am getting the dreaded online (VPN Disco...
- Feb 08, 2017
The VPN disconnected was due to a problem with the VPN server. We resolved the issue middle of last week. Anything you are experiencing since middle of last weeks is unrelated to the main issue that occurred on the server at the end of January.
mrselyod
Jan 30, 2017Aspirant
I am having the same issue today -was working fine last week. I'm just trying to upgrade the client to see if it makes any difference.
Edit: It didn't.
LilRos
Have same problem today, normally fixed quite quickly but today not! Just called tech support and weren't aware of problem! I'm told its now logged and should be fixed soon! Finger crossed as I've got grumpy users today!
- BrendanMJan 30, 2017NETGEAR Expert
We are seeing multiple customers reporting similar problems. The engineering team are looking into it with high priority.
- rayray1Jan 30, 2017Aspirant
we have clients that are experienicing the same..
oddly enough our account works. been fine for months.
today.. online with vpn disconnected.
- flattenedJan 30, 2017Apprentice
Same here too today (30th Jan 2017), with no physical reason to explain it. Logging into the Readycloud webpage shows the shares so I know they are there.
- rvillaJan 30, 2017Aspirant
What is the expected resolution time?
- clinfordJan 30, 2017Aspirant
We too are having the same issue for us and our clients.
Is there an update on the resolution?
- thadandersJan 30, 2017Aspirant
Is there a way I can get notified when there's a change of status on this problem? It's comforting to know Netgear engineers are looking into it for now. Thanks!
- FloodlightMediaJan 30, 2017Aspirant
As a possible workaround/backup, ownCloud was recommended in an earlier thread I was just reading and I'm looking forward to testing it out since ReadyCloud has just been a never-ending nightmare for us.
Latest plugin for ReadyNas: https://rnxtras.com/add-ons/update/owncloud-9-1-3-all-readynas-platforms-79444
Desktop and Mobile Apps: https://owncloud.org/install/#
