davesumm
Jan 29, 2017Luminary
VPN Disconnected
Hi, all Is there any new known problem with readycloud? I'm struggling to connect to 2 different NAS systems remotely from my work PCs (2 different PCs) I am getting the dreaded online (VPN Disco...
- Feb 08, 2017
The VPN disconnected was due to a problem with the VPN server. We resolved the issue middle of last week. Anything you are experiencing since middle of last weeks is unrelated to the main issue that occurred on the server at the end of January.
Rightway_env
Jan 31, 2017Aspirant
Same here, I've been rebuilding a laptop for our team due to HDD failure. When reinstalled Readycloud initially worked but after I had installed Teamviewer I got the VPN disconnected message. I thought it might have caused an issue but it's unlikely Teamviewer would have affected it. After 2 more rebuilds and installs (without teamviewer, though that's probably irrelevant) I'm getting the same problem. I will be able to test oure other machines later today but it looks like this is a wider issue.
