davesumm
Jan 29, 2017Luminary
VPN Disconnected
Hi, all Is there any new known problem with readycloud? I'm struggling to connect to 2 different NAS systems remotely from my work PCs (2 different PCs) I am getting the dreaded online (VPN Disco...
- Feb 08, 2017
The VPN disconnected was due to a problem with the VPN server. We resolved the issue middle of last week. Anything you are experiencing since middle of last weeks is unrelated to the main issue that occurred on the server at the end of January.
norrispackard
Jan 31, 2017Tutor
Hi,
i have the same issue since 3 days,
No upgrade done, no apparent change on the structures.
VPN disconnected - android function well - webpage OK
norrispackard
Jan 31, 2017Tutor
FYI
i try using thetering by my phone without result.. still try othe ways..
- STX1300MANFeb 01, 2017Star
This is ridiculous! When is Netgear going to make an official annoncement about this?
For many users the remote access function was one of the key atractions of a NAS.
Having convinced some of my users Netgear ReadyNAS was THE way to go, I'm now getting lots of flack that they should have used a Cloud service like Google Drive or Mcrosoft's One Drive. How can I argue when we are having a major outage like this and NO support?
Grrrrrrr!
- prauFeb 01, 2017Aspirant
Yes the problem still continues and it looks that Netgear doesn't care. May be that's why we will want Netgear never more. Now I'm sure, that on the end of life time of my device I'll chose another brand. :-/ ... May be cheaper with better quality and support.
