davesumm
Jan 29, 2017Luminary
VPN Disconnected
Hi, all Is there any new known problem with readycloud? I'm struggling to connect to 2 different NAS systems remotely from my work PCs (2 different PCs) I am getting the dreaded online (VPN Disco...
- Feb 08, 2017
The VPN disconnected was due to a problem with the VPN server. We resolved the issue middle of last week. Anything you are experiencing since middle of last weeks is unrelated to the main issue that occurred on the server at the end of January.
Feb 02, 2017Guru - Experienced User
mc41 wrote:
photos = access denied ??
Maybe reset permissions in the photos share.
mc41
Feb 02, 2017Aspirant
How do you reset ?
- StephenBFeb 02, 2017Guru - Experienced User
mc41 wrote:
How do you reset ?
Go into the admin ui's share list, and select the settings wheel for the share. On the file access tab you'll see a reset control which resets permissions to the factory default. Do that, and see if it resolves the problem. If it does, you can then try re-applying the permissions you want (if they are not the defaults).
- mc41Feb 02, 2017Aspirant
Ok did the reset,same problem access denied
also the 2 green lights
1= internet available
2 X (red) unable to connect services
still can access all from the http://readycloud.netgear.com/client/en/welcome.html
Is the iPad using the same credentials you are using with the portal?
