davesumm
Jan 29, 2017Luminary
VPN Disconnected
Hi, all Is there any new known problem with readycloud? I'm struggling to connect to 2 different NAS systems remotely from my work PCs (2 different PCs) I am getting the dreaded online (VPN Disco...
- Feb 08, 2017
The VPN disconnected was due to a problem with the VPN server. We resolved the issue middle of last week. Anything you are experiencing since middle of last weeks is unrelated to the main issue that occurred on the server at the end of January.
Densterdad
Feb 02, 2017Aspirant
ReadyNAS problem solved!!!! I'm able to login again.
JD1
Feb 02, 2017Guide
Thanks for the update. I was able to successfully get connected through ReadyCloud VPN this morning. Now, I think that Netgear needs to give us all one year phone support to make it up to there awesome customers.
- StephenBFeb 02, 2017Guru - Experienced User
FWIW I have suggested that communication on service outages needs to be improved.
I also posted one suggestion in the idea exchange that you might vote for if you think it would serve. https://community.netgear.com/t5/Idea-Exchange-for-ReadyNAS/Opt-in-for-emails-related-to-ReadyCloud-Remote-services-outages/idi-p/1221166#M798
As a reminder, you vote by clicking on the large up arrow next to the idea.
