ReadyJoe
Sep 18, 2015Tutor
Why Did ReadCLOUD Create Folders on My Hard Drive?
This morning when I fired up my computer my startup hard disk was full. It created lots of problems. ReadyCLOUD created backup folders on my computer and copied files from my computer into these fol...
- Sep 26, 2015
Hello,
Yes I believe so. If you start a new backup without deleting the backup share first a new one will be created with the same name and a "-2" added.
Bye,
Eskender
EskenderNG
Sep 18, 2015NETGEAR Employee Retired
Hello,
the intended use of the sync function begins with a share on your ReadyNAS containing data. If you then enable sync in the ReadyCLOUD App for this share a folder on your PC will be created and all files synced to this new folder. For Windows this folder is within you’re your user directory/ReadyCLOUD.
Could you please confirm each step that you took that had you end up with a local duplicate of your data?
Thanks,
Eskender
