ReadyJoe
Sep 18, 2015Tutor
Why Did ReadCLOUD Create Folders on My Hard Drive?
This morning when I fired up my computer my startup hard disk was full. It created lots of problems. ReadyCLOUD created backup folders on my computer and copied files from my computer into these fol...
- Sep 26, 2015
Hello,
Yes I believe so. If you start a new backup without deleting the backup share first a new one will be created with the same name and a "-2" added.
Bye,
Eskender
EskenderNG
Sep 26, 2015NETGEAR Employee Retired
Hello,
Bye,
Eskender
Retired_Member
Oct 10, 2015Same thing happened to me on a Windows 7 Laptop, I assumed that once folders on the PC were "backed up" to Readycloud that the Sync function would simply adjust any changes within each folder ie if more documents or images were added to the appropriate folder. My HD filled up rapidly now I think I understand why, the folder created on my PC under Favourites in Windows Explorer was the result I guess. Thanks for the explanation. Cheers
