Pete10p
May 22, 2021Aspirant
admin login keeps cycling every 2-3 seconds
I have just upgraded to 6.10.5 and now I can't get into the admin page. I can log in as usual but after 2-3 seconds I am asked to log in again. This keeps cycling. I have cleared the browser caches...
May 22, 2021Guru - Experienced User
Try internet explorer. One poster found he could get in using that - but only when he didn't maximize the browser window.
- Pete10pMay 22, 2021Aspirant
Thanks for the response.
I’ve tried Explorer both full and part screen without any luck. I have also reset the OS. With the OS reset to default it works OK until I restore the config and then the same problem occurs. The config has worked for years. It looks like it is accepting the login password but its stuck in a loop.
I have also changed my router setting to temporarily allow internet access but that hasn’t fixed it either.- StephenBMay 22, 2021Guru - Experienced User
That is interesting. Do you have ReadyCloud (or other cloud apps) turned on in your original config?
No, none
Im justing trying to revert back to te previous version. but reinstalling the config is proving to be a problem with unknown server message popping up when trying to restore the file
