Pete10p
May 22, 2021Aspirant
admin login keeps cycling every 2-3 seconds
I have just upgraded to 6.10.5 and now I can't get into the admin page. I can log in as usual but after 2-3 seconds I am asked to log in again. This keeps cycling. I have cleared the browser caches...
May 22, 2021Guru - Experienced User
Try internet explorer. One poster found he could get in using that - but only when he didn't maximize the browser window.
Pete10p
Thanks for the response.
I’ve tried Explorer both full and part screen without any luck. I have also reset the OS. With the OS reset to default it works OK until I restore the config and then the same problem occurs. The config has worked for years. It looks like it is accepting the login password but its stuck in a loop.
I have also changed my router setting to temporarily allow internet access but that hasn’t fixed it either.
- StephenBMay 22, 2021Guru - Experienced User
That is interesting. Do you have ReadyCloud (or other cloud apps) turned on in your original config?
- Pete10pMay 22, 2021Aspirant
No, none
Im justing trying to revert back to te previous version. but reinstalling the config is proving to be a problem with unknown server message popping up when trying to restore the file
