Pete10p
May 22, 2021Aspirant
admin login keeps cycling every 2-3 seconds
I have just upgraded to 6.10.5 and now I can't get into the admin page. I can log in as usual but after 2-3 seconds I am asked to log in again. This keeps cycling. I have cleared the browser caches...
Sandshark
May 22, 2021Sensei
I'm beginning to wonder if there isn't something about the password itself that's causing the problem. In another thread, a user has this problem on one of multiple NAS. I wonder if they all have the same password.
Pete10p
May 23, 2021Aspirant
I’ve tried a simple password and the problem persists.
What I don’t get is why if I reboot the OS and sign in with the default "password" password it works ok. Changing the password seems to make the problem happen. I'm going try changing the default password to "password" to see if its the process of change that is causing the problem rather than the characters use.
I have also tried opening my firewall. Normally the ReadyNas units are isolated from the internet. This has note made any difference.
- Pete10pMay 23, 2021Aspirant
The password changing process seems to be the problem. I rebooted the OS again, logged in using "password" system worked fine. I changed the password to "password" and that created the loop problem. It looks like a bug. How do I get Netgear help for a bug without paying them £80?
- JohnCM_SMay 25, 2021NETGEAR Employee Retired
Hi Pete10p,
We would like to further investigate this issue. Can you reproduce the issue then download the NAS system log and provide it to us? You may upload the logs to a cloud storage site (Google Drive, Dropbox, etc) then send me the download link via private message.
- Pete10pMay 26, 2021Aspirant
Thanks
I don't use cloud storage so will need to set up a account
Thanks for the assistance. I have set up a Dropbox account. which email addrsss should I use
- JohnCM_SMay 26, 2021NETGEAR Employee Retired
Hi Pete10p,
You may just send the download link to me via private message. You can send a private message by clicking the envelope icon located in the top right corner.
- JohnCM_SJun 26, 2021NETGEAR Employee Retired
Hi Pete10p,
The fix has been applied. Can you check if you can now access the GUI with no issues?
Thank you.
- Pete10pJun 26, 2021Aspirant
That seems to have fixed the problem. I really appreciate your help.
How do I apply the fix to my other ReadyNas. I reinstalled 6.10.4 do I need to upgrade to 6.10.5?
Hi Pete10p,
Yes, please update it first to 6.10.5, enable remote access to the NAS, then send me the 5-digit debug code via private message.
Regards, - yobanJun 26, 2021Apprentice
Pete10p wrote:That seems to have fixed the problem. I really appreciate your help.
JohnCM_Sit would be good to know what the fix is for all users and if it will be incorporated in to future hot patches/updates
- Pete10pJun 27, 2021Aspirant
I have done the upgrade
access number 56195
- richard42ackJul 31, 2021Guide
Same problem here. No matter from which machine or OS, Netgear router will bounce back to the login screen on almost every attempt to click on the menus. How can I fix anything with this router if it won't stay logged in to the point I could actually do anything with it.
This behavior started yesterday. I have been unable, despite numerous tries, to get anything done or to even see what the problem might be. This is a WAC124
What do I do now to fix this?
I have tried disconnecting from the WAN, but it still comes back with 'checking the internet connection' (why? there isn't one) and then logs me out. I can, at most touch 3 menu items before it does this.
- StephenBJul 31, 2021Guru - Experienced User
richard42ack wrote:
Same problem here.
Sorry, no. You posted in the ReadyNAS forum area, and the issue here was solved with a hotfix from Netgear.
Your wireless access point problem is different, and you should repost it in the right forum area.
- SandsharkJul 31, 2021Sensei
If the NAS has no internet connection, then it cannot load HotFix1 to OS6.10.5 that fixes that issue.
- richard42ackAug 01, 2021Guide
Ah. OK. Thanks. This came up with a search, didn't notice that detail. Pretty similar from the very first message -- getting kicked out of admin. If anyone is able, my items here can be deleted (doesn't seem I can do that).
