mfe_
Dec 05, 2012Tutor
Advice compiling php
Hello, I'm trying to compile php from source by using gcc 4.6.0 on the readynas duo sparc. I read the php.net manual which says I have to set the parameter --with-apxs2= The only apxs file I fou...
mfe_
Dec 12, 2012Tutor
Hi,
thanks for the replies. I'm able to compile php php-5.4.9 without the parameter --with-apxs2=/c/home/admin/support/apxs with my gcc 4.6.0 + upgraded tools.
Configuring php with ../php-5.3.10/configure --exec-prefix=/usr/lib/apache2 --with-apxs2=/c/home/admin/support/apxs --host=sparc-linux will break at:
As we know Perl is installed on the readynas duo. In addition I figured out that apache2 was compiled with enable-so (checked with apache2 -l). The message "sh: line 1: /usr/local/apache2/bin/envvars: No such file or directory" is confusing.
I edited /homes/admin/support/apxs and changed the paths to:
An other problem is that printing perl variables in the apxs file will be suppressed. So maybe I have to create a seperated perl script to dump "
The config.log last line is:
and doenst support any more information :(
Another idea whould be to create the missing folders and copy the apache files into these directories? But first I will try to dump the perl variables and look forward.
greetings and best regards
checking for Apache 1.x module support... no
checking whether to enable Apache charset compatibility option... no
checking for Apache 2.0 filter-module support via DSO through APXS... no
checking for Apache 2.0 handler-module support via DSO through APXS...
Sorry, I cannot run apxs. Possible reasons follow:
1. Perl is not installed
2. apxs was not found. Try to pass the path using --with-apxs2=/path/to/apxs
3. Apache was not built using --enable-so (the apxs usage page is displayed)
The output of /c/home/admin/support/apxs follows:
apxs:Error: Sorry, no shared object support for Apache.
apxs:Error: available under your platform. Make sure.
apxs:Error: the Apache module mod_so is compiled into.
apxs:Error: your server binary `/c/home/admin/'..
configure: error: Aborting
my $installbuilddir = "/usr/sbin/apache2"; ##"/usr/local/apache2/build";so the paths should be correct. Why is it me telling that the path in "sh: line 1:" / is incorrect? This is a perl script and not a shell script. Is it possible that the error does not occour in the apxs file, because the error is in a shell script on line 1? 0o Or am I searching the error in the wrong file?
##get_config_vars("$installbuilddir/config_vars.mk",\%config_vars);
get_config_vars("/c/home/admin/build/config_vars.mk",\%config_vars);
my $httpd = get_vars("sbindir") . "/" . get_vars("progname");
$httpd = eval qq("$httpd");
my $envvars = get_vars("sbindir") . "/envvars";
$envvars = eval qq("$envvars");
".The config.log last line is:
configure:5271: checking whether to enable Apache charset compatibility option
configure:5438: checking for Apache 2.0 filter-module support via DSO through APXS
configure:6327: checking for Apache 2.0 handler-module support via DSO through APXS
