JanvdBrink
Feb 01, 2016Tutor
Anti-Virus Plus detects but not removes adware/malware
Hello, I have a Readynas RN102 with 6.4.1. firmware. I have Anti-Virus Plus installed. Today it started detecting Adware (W32/Adware.DEZV-3749 or NsCPUMiner32.exe) and Bitcoinminer trojan (W64Adw...
- Feb 03, 2016
Ha Kodhee,
Thanks. I always keep my antivirus up to date. So that might be the reason no virus is detected (asuming it was a false detection as well).
I did what you suggested and selected / deselected the files of several maps in which the 'infected' files were located. That was an hour ago and I did not get any message. Neither did my scan I scheduled tonight.
So I'll keep my fingers crossed and do a last check tomorrow morning.
JanvdBrink
Feb 01, 2016Tutor
Hi Steven,
Thanks for the reply. The issue is I just cannot view the info.zip file. Because the scanner detects the file I guess it's present. The good news is that this info.zip file should not be present in the folders. So, íf i can view it, there's no problem deleting it.
My point is that I hoped the scanner would delete the file, but it does not.
Thanks,
Jan
Feb 01, 2016Guru - Experienced User
Perhaps it is embedded in another zip file?
It is a bit troubling, you should be able to find it (since the system says it didn't delete it).
