jereaa
Oct 09, 2018Aspirant
Antivirus is not updating (ReadyNAS OS 6.9.4)
I've just installed my new ReadyNAS 214.
First thing I did was to update the OS to version 6.9.4, so I can tell I am connected to the internet.
The antivirus, being enabled or disabled, is al...
JohnCM_S
Oct 10, 2018NETGEAR Employee Retired
Hi jereaa,
Welcome to the Community!
You can try assigning a static DNS on the NAS and see if that helps.
- jereaaOct 10, 2018Aspirant
Did it, and nothing changed. Still have the same problem :/
- JohnCM_SOct 11, 2018NETGEAR Employee Retired
Hi jereaa,
Can you download the logs and the send it to me? You can upload that to a file sharing site and then PM me the download link.
- JohnCM_SOct 12, 2018NETGEAR Employee Retired
Hi jereaa,
Can you also enable the Secure Diagnostic Mode on the NAS? We will check if the NAS can really reach the Internet. You can enable that by going System > Settings > Support then PM me the 5-digit number. We will check if we can see that port.
