jereaa
Oct 09, 2018Aspirant
Antivirus is not updating (ReadyNAS OS 6.9.4)
I've just installed my new ReadyNAS 214.
First thing I did was to update the OS to version 6.9.4, so I can tell I am connected to the internet.
The antivirus, being enabled or disabled, is al...
jereaa
Oct 10, 2018Aspirant
Did it, and nothing changed. Still have the same problem :/
JohnCM_S
Oct 11, 2018NETGEAR Employee Retired
Hi jereaa,
Can you download the logs and the send it to me? You can upload that to a file sharing site and then PM me the download link.
- JohnCM_SOct 12, 2018NETGEAR Employee Retired
Hi jereaa,
Can you also enable the Secure Diagnostic Mode on the NAS? We will check if the NAS can really reach the Internet. You can enable that by going System > Settings > Support then PM me the 5-digit number. We will check if we can see that port.
- jereaaOct 12, 2018Aspirant
I've enabled the Secure Diagnostic Mode and PM'ed you the port.
Thanks for your help.
Hi jereaa,
ClamAV has an automatic way to update, which is called FreshClam. One of our L3's ran it on debug mode. It can talk to the server but when it gets to 99%, it just stops receiving the data.
It was also found that we have an old version of ClamAV on the NAS. L3 tried updating it but seems like something is killing the connection at the very last second.
We would like to gather information about your network. I have listed below the information that we needed:
1. Name of ISP
2. Brand and model of the firewall router
3. What devices are connected in between the NAS and the firewall?
- Andrew_DMOct 19, 2018Tutor
Hi JohnCM_S,
We have RN31400-100EUS with 4x2TB disks 12% full XRAID upgraded to 6.9.4 now since October 16 saying the same error. Looking in system.log ClamAV version 0.99.3 error recommending 0.100.2 and all daily .cdiff 100% successful but the buildcld can't add the daily.hdb to the new daily.cld and hence fails to update. looked at /dev/md0 and of the 4GB its got <300MB left but that isn't the error - looks like with some offline testing its the included ClamAV version 0.99.3 thats the problem as the new signatures are not backwards compatible to before version 0.100.2
So can this be a fix in 6.9.5 sharpish??
Andrew
- Andrew_DMNov 21, 2018Tutor
Ah after much testing the signatures are fine with v0.99.3 of ClamAV.
The problem turned out to be the signature files had become enormous and then corrupt in /var/lib/clamav so with a quick name change to .bck on mirrors.dat, main.cvd and daily.cvd then running freshclam -v all is good again and we have 100% AV working without issue, so have deleted the three old .bck files and all is fine...
Cheers and regards, Andrew.
- dsnpevlMar 23, 2019Virtuoso
Thanks for sharing this! Ran into something very similar on RN516 with 6.9.5 today. Only my 3 files were called *.cld instead of *.cvd.
Another issues seemed to be the outdated version of ClamAV: "WARNING: Your ClamAV installation is OUTDATED!"?
After running below procedure as you desribed with "freshclam -v", the antivirus was updated again. Not sure if "bytecode.cld" should also be replaced? This is the only file that doesn't have the date updated to March 23rd.
root@nas-XX-XX-XX:~# cd /var/lib/clamav root@nas-XX-XX-XX:/var/lib/clamav# ls -al total 465448 drwxr-xr-x 1 clamav clamav 188 Mar 23 07:19 . drwxr-xr-x 1 root root 386 Jan 25 00:19 .. -rw-r--r-- 1 root root 48 Feb 25 00:58 antivir.ini -rw-r--r-- 1 root root 1013248 Jan 2 16:35 bytecode.cld drwxr-xr-x 1 root root 86 Mar 23 07:19 clamav-c1a4aff7c81d68089aa22a9faf0135c9.tmp -rw-r--r-- 1 root root 168092160 Feb 25 00:58 daily.cld -rw-r--r-- 1 root root 307499008 Jun 8 2017 main.cld -rw------- 1 root root 1248 Mar 23 07:19 mirrors.dat root@nas-XX-XX-XX:/var/lib/clamav# mv daily.cld daily.bck root@nas-XX-XX-XX:/var/lib/clamav# mv mirrors.dat mirrors.bck root@nas-XX-XX-XX:/var/lib/clamav# mv main.cld main.bck root@nas-XX-XX-XX:/var/lib/clamav# freshclam -v Current working dir is /var/lib/clamav Max retries == 5 ClamAV update process started at Sat Mar 23 08:24:42 2019 Using IPv6 aware code Querying current.cvd.clamav.net TTL: 1122 Software version from DNS: 0.101.1 WARNING: Your ClamAV installation is OUTDATED! WARNING: Local version: 0.100.2 Recommended version: 0.101.1 DON'T PANIC! Read https://www.clamav.net/documents/upgrading-clamav Retrieving http://database.clamav.net/main.cvd Trying to download http://database.clamav.net/main.cvd (IP: 2606:4700::6810:da54) Downloading main.cvd [100%] Loading signatures from main.cvd Properly loaded 4566249 signatures from new main.cvd main.cvd updated (version: 58, sigs: 4566249, f-level: 60, builder: sigmgr) Querying main.58.93.1.0.2606470000000000000000006810da54.ping.clamav.net Retrieving http://database.clamav.net/daily.cvd Trying to download http://database.clamav.net/daily.cvd (IP: 2606:4700::6810:da54) Downloading daily.cvd [100%] Loading signatures from daily.cvd Properly loaded 1528057 signatures from new daily.cvd daily.cvd updated (version: 25396, sigs: 1528057, f-level: 63, builder: raynman) Querying daily.25396.93.1.0.2606470000000000000000006810da54.ping.clamav.net bytecode.cvd version from DNS: 328 bytecode.cld is up to date (version: 328, sigs: 94, f-level: 63, builder: neo) Database updated (6094400 signatures) from database.clamav.net (IP: 2606:4700::6810:da54) Clamd successfully notified about the update. root@nas-XX-XX-XX:/var/lib/clamav# root@nas-XX-XX-XX:/var/lib/clamav# rm *.bck root@nas-XX-XX-XX:/var/lib/clamav# ls -al total 154624 drwxr-xr-x 1 clamav clamav 188 Mar 23 08:27 . drwxr-xr-x 1 root root 386 Jan 25 00:19 .. -rw-r--r-- 1 root root 48 Mar 23 08:25 antivir.ini -rw-r--r-- 1 root root 1013248 Jan 2 16:35 bytecode.cld drwxr-xr-x 1 root root 86 Mar 23 07:19 clamav-c1a4aff7c81d68089aa22a9faf0135c9.tmp -rw-r--r-- 1 root root 39414942 Mar 23 08:25 daily.cvd -rw-r--r-- 1 root root 117892267 Mar 23 08:24 main.cvd -rw------- 1 root root 52 Mar 23 08:25 mirrors.dat ? ?
