siggek
Mar 14, 2019Aspirant
Antivirus stopped updating
The antivirus stopped updating a couple of weeks ago. I tried updating os to 6.9.5 but i stilldo not update.
Tried running host -t txt current.cvd.clamav.net which returned a long string of numbers...
- Mar 17, 2019
Note that starting with 6.10.x, netgear is dropping antivirus on the RN100 series. See item 19 here: https://community.netgear.com/t5/ReadyNAS-Beta/ReadyNASOS-6-10-0-RC2/m-p/1651396#M10285
OOM-9
Mar 15, 2019NETGEAR Expert
Which ReadyNAS unit are you using?
Hopchen
Mar 15, 2019Prodigy
Hey OOM-9
I will add my two cents to this. I checked on my unit here: RN422 running 6.9.5.
AV did update the definitions.
root@Datastore:~# tail -n1 /var/log/frontview/status.log [19/03/15 22:12:56 WET] notice:system:LOGMSG_ANTIVIRUS_DEF_UPDATE Antivirus scanner definition file was updated to 58.25389.
The AV version itself is outdated though, same as siggek
root@Datastore:~# freshclam ClamAV update process started at Fri Mar 15 22:53:38 2019 WARNING: Your ClamAV installation is OUTDATED! WARNING: Local version: 0.100.2 Recommended version: 0.101.1 DON'T PANIC! Read https://www.clamav.net/documents/upgrading-clamav main.cvd is up to date (version: 58, sigs: 4566249, f-level: 60, builder: sigmgr) daily.cvd is up to date (version: 25389, sigs: 1518483, f-level: 63, builder: raynman) bytecode.cvd is up to date (version: 328, sigs: 94, f-level: 63, builder: neo)
When doing verbose status it seems that the AV engine tries to update via: current.cvd.clamav.net
root@Datastore:~# freshclam -v Current working dir is /var/lib/clamav Max retries == 5 ClamAV update process started at Fri Mar 15 22:54:36 2019 Using IPv6 aware code Querying current.cvd.clamav.net TTL: 1183 Software version from DNS: 0.101.1 WARNING: Your ClamAV installation is OUTDATED! WARNING: Local version: 0.100.2 Recommended version: 0.101.1 DON'T PANIC! Read https://www.clamav.net/documents/upgrading-clamav main.cvd version from DNS: 58 main.cvd is up to date (version: 58, sigs: 4566249, f-level: 60, builder: sigmgr) daily.cvd version from DNS: 25389 daily.cvd is up to date (version: 25389, sigs: 1518483, f-level: 63, builder: raynman) bytecode.cvd version from DNS: 328 bytecode.cvd is up to date (version: 328, sigs: 94, f-level: 63, builder: neo)
If I try to resolve that address, even with Google DNS, it does not resolve.
root@Datastore:~# nslookup current.cvd.clamav.net 8.8.8.8 Server: 8.8.8.8 Address 1: 8.8.8.8 google-public-dns-a.google.com nslookup: can't resolve 'current.cvd.clamav.net'
I am not sure how the updates are done exactly and if the problem is that unresolvable address? I can see that freshclam accessed the mirrors successfully when it updated the definitions though.
root@Datastore:~# freshclam --list-mirrors Mirror #1 IP: 104.16.218.84 Successes: 2 Failures: 0 Last access: Fri Mar 15 22:12:21 2019 Ignore: No
Cheers
- StephenBMar 16, 2019Guru - Experienced User
Cloudflare (1.1.1.1) doesn't resolve it either.
Likely this is on ClamAV (FWIW I have seen issues with their DNS before).
- HopchenMar 16, 2019Prodigy
Alright, so after a bit of digging around I realised that current.cvd.clamav.net is not a DNS A record. This explains why it does not resolve upon normal DNS lookup :)
Instead it is a TXT record and querying it correctly actually works fine. You can query it, as OP said, with:
That works fine.
So yeah, not sure why the ClamAV engine does not update to the latest version.
So, after a reboot of the NAS and then running freshclam it did some more updates of the virus database.
ClamAV update process started at Sat Mar 16 15:38:03 2019
Downloading daily-25390.cdiff [100%]
daily.cld updated (version: 25390, sigs: 1520006, f-level: 63, builder: raynman)
Database updated (6086349 signatures) from database.clamav.net (IP: 104.16.219.84)
Clamd successfully notified about the update.Clamscan is now running on the NAS as I suppose it is re-scanning files as the AV signatures are updated. I will leave it run and see what happens.
The AV engine is the same version as before but I suppose that gets updated in a different way - not 100% sure about the upgrade process for that.
Cheers
