siggek
Mar 14, 2019Aspirant
Antivirus stopped updating
The antivirus stopped updating a couple of weeks ago. I tried updating os to 6.9.5 but i stilldo not update.
Tried running host -t txt current.cvd.clamav.net which returned a long string of numbers...
- Mar 17, 2019
Note that starting with 6.10.x, netgear is dropping antivirus on the RN100 series. See item 19 here: https://community.netgear.com/t5/ReadyNAS-Beta/ReadyNASOS-6-10-0-RC2/m-p/1651396#M10285
siggek
Mar 16, 2019Aspirant
I only get to the dowload, then the process seems to hang or get to an infinite loop.
root@ReadyNAS:~# freshclam -v
Current working dir is /var/lib/clamav
Max retries == 5
ClamAV update process started at Sat Mar 16 17:11:55 2019
Using IPv6 aware code
Querying current.cvd.clamav.net
TTL: 235
Software version from DNS: 0.101.1
WARNING: Your ClamAV installation is OUTDATED!
WARNING: Local version: 0.100.2 Recommended version: 0.101.1
DON'T PANIC! Read https://www.clamav.net/documents/upgrading-clamav
main.cvd version from DNS: 58
main.cld is up to date (version: 58, sigs: 4566249, f-level: 60, builder: sigmgr)
daily.cvd version from DNS: 25390
Retrieving http://database.clamav.net/daily-25380.cdiff
Trying to download http://database.clamav.net/daily-25380.cdiff (IP: 104.16.218.84)
Downloading daily-25380.cdiff [100%]
Then reshclam process takes 80% CPU:
PID USER PR NI VIRT RES SHR S %CPU %MEM TIME+ COMMAND
12648 root 20 0 14448 9672 4976 R 81.8 1.9 8:58.20 freshclam
Cheers
Mar 17, 2019Guru - Experienced User
