ORTech
Feb 23, 2016Aspirant
Apps not appearing or launching...
I wanted to convey an observation, to get it "on the books" so to speak, regarding the available Apps not showing their images on the Available Apps page and after loading an App, getting a 404 page ...
siigna
Feb 23, 2016NETGEAR Employee Retired
I did some quick testing and couldn't see the same issues on 6.4.1. Updated to 6.4.2 and still good. Factory default on 6.4.2 and still good.
Apps are stored under the (oldest) volume in a subvolume called ".apps". It's also mounted to "/apps" on the system. A share named "Apps" (or "apps", I tried both) shouldn't conflict with the apps system.
Still have that system running? I wouldn't mind taking a look through the logs. You can send them over using these instructions.
- ORTechFeb 24, 2016Aspirant
Logs sent for your review siigna.
- siignaMar 11, 2016NETGEAR Employee Retired
Sorry for the delays. I looked into this issue, but the only way I could reproduce it was by enabling HTTP access to the share. An internal bug has been filed to look into this further.
- ORTechMar 14, 2016Aspirant
That would make sense in my mind as the routing of the HTTP path to share (named Apps) and the page to display the onboard apps seem to be getting confused. Yes, I have HTTP to the share enabled.
Thanks for filing the bug notice.
In the meantime I've changed the shares' name on my units.
