Rockman
May 05, 2016Aspirant
Apps Will not Download/Install to RN104
When I try and install any of the many available apps listed, the Progress Bar says "Downloading" and shortly thereafter I get a box that says "Apps operation failed" and "Aplication xyz cannot be do...
- May 09, 2016
Well, I have no idea what I did right but things seems to be working. I reloaded the OS for the upteenth time, set the static IP address for my network and rebooted. Suddenly RC "sees" the machine and the app downloaded/installed. Beats the heck out of me.
Just sign me as "clueless"
mdgm-ntgr
May 05, 2016NETGEAR Employee Retired
Do your email alerts work?
If you set a static I.P. address on the NAS did you remember to specify the DNS server addresses?
- RockmanMay 07, 2016Aspirant
mdgm wrote:Do your email alerts work?
If you set a static I.P. address on the NAS did you remember to specify the DNS server addresses?Yes, the DNS Servers are all set. I tried to get email set up since you asked but unsuccessfully so far. Keepts saying "check smtp settings" and other than Outlook is set to SSL and this software says TLS, the Outgoing Server, Port, and id settings are all the same.
- StephenBMay 07, 2016Guru - Experienced User
Is Outlook using an SMTP server?
- RockmanMay 09, 2016Aspirant
Yes it is. I set the RN to the same settings.
Sidenote: As a test, I downloaded Photo-II using this browser from the webside and uploaded using the RN and it installed on the RN just fine. It's not the App I really wanted however but at least I know apps should install if I can download them. I have no idea about the email.
