Rockman
May 05, 2016Aspirant
Apps Will not Download/Install to RN104
When I try and install any of the many available apps listed, the Progress Bar says "Downloading" and shortly thereafter I get a box that says "Apps operation failed" and "Aplication xyz cannot be do...
- May 09, 2016
Well, I have no idea what I did right but things seems to be working. I reloaded the OS for the upteenth time, set the static IP address for my network and rebooted. Suddenly RC "sees" the machine and the app downloaded/installed. Beats the heck out of me.
Just sign me as "clueless"
Retired_Member
May 09, 2016The easiest way to check Internet Connectivity from the GUI is to click "Check for Update" in home page. If you get a message (Update available or not update available), it means Internet Connectivity is OK. If you don't get any message, it's not ;)
- RockmanMay 09, 2016Aspirant
