chrizn
Feb 15, 2015Aspirant
Asterisk 404 no Web Access after initial install
Hi there, I run the following: RN104 OS 6.2.2 I installed Asterisk Add-on but when I launch it from the RN admin console, the initial config page IP Address:8088/asterisk/static/config/inde...
RX
Feb 23, 2015Luminary
What if you try to perform OS reinstall on your RN104 then try to install the Asterisk App again.
Also if you can still access the web-GUI, you might want to consider trying the Beta Firmware v6.2.3: viewtopic.php?t=78866
- Aug 16, 2018Retired_Member
