chopsywa
Jan 31, 2014Aspirant
Asterisk app missing critical lib module
Hi guys The Asterisk app installs fine, but the SIP functionality is non-existent as it appears the chan-sip module is missing from the package. I have re installed in case it was an install gli...
kedar
Feb 19, 2014Aspirant
Hi Mark
Is chan-sip module the only functionality missing or other things also? Can you please send me list of modules (functionality) missing. It will help me correct all of them at once.
I found chan-sip module is disabled in 1.8.25.0 version (included in asterisk-app_1.0.4_all.deb) and enabled in asterisk-10.0.0. This is also disabled in 11.7.0 version.
Below are the options available in 1.8..25, 10.0.0 and 11.7.0 version when ran 'help' command from asterisk CLI.
Connected to Asterisk 10.0.0 currently running on nas-07-13-34 (pid = 9811)
nas-07-13-34*CLI> help
! Execute a shell command
ael reload Reload AEL configuration
ael set debug {read|tokens|mac Enable AEL debugging flags
agent logoff Sets an agent offline
agent show Show status of agents
agent show online Show all online agents
agi dump html Dumps a list of AGI commands in HTML format
agi exec Add AGI command to a channel in Async AGI
agi set debug [on|off] Enable/Disable AGI debugging
agi show commands [topic] List AGI commands or specific help
aoc set debug enable cli debugging of AOC messages
calendar dump sched Dump calendar sched context
calendar show calendar Display information about a calendar
calendar show calendars Show registered calendars
calendar show types Show all calendar types loaded
cc cancel Kill a CC transaction
cc report status Reports CC stats
cdr show status Display the CDR status
cel show status Display the CEL status
channel originate Originate a call
channel redirect Redirect a call
channel request hangup Request a hangup on a given channel
cli check permissions Try a permissions config for a user
cli reload permissions Reload CLI permissions config
cli show aliases Show CLI command aliases
cli show permissions Show CLI permissions
confbridge kick Kick participants out of conference bridges.
confbridge list List conference bridges and participants.
confbridge lock Lock a conference.
confbridge mute Mute a participant.
confbridge record start Start recording a conference
confbridge record stop Stop recording a conference.
confbridge show menu Show a conference menu
confbridge show menus Show a list of conference menus
confbridge show profile bridge Show a conference bridge profile.
confbridge show profile bridge Show a list of conference bridge profiles.
confbridge show profile user Show a conference user profile.
confbridge show profile users Show a list of conference user profiles.
confbridge unlock Unlock a conference.
confbridge unmute Unmute a participant.
config list Show all files that have loaded a configuration file
config reload Force a reload on modules using a particular configuration file
console answer Answer an incoming console call
console boost Sets/displays mic boost in dB
console dial Dial an extension on the console
console flash Flash a call on the console
console hangup Hangup a call on the console
console {mute|unmute} [toggle] Disable/Enable mic input
console send text Send text to the remote device
console transfer Transfer a call to a different extension
console {device} Generic console command
console {set|show} autoanswer Sets/displays autoanswer
console {set|show} active [<de Sets/displays active console
core abort shutdown Cancel a running shutdown
core clear profile Clear profiling info
core ping taskprocessor Ping a named task processor
core reload Global reload
core restart gracefully Restart Asterisk gracefully
core restart now Restart Asterisk immediately
core restart when convenient Restart Asterisk at empty call volume
core set debug channel Enable/disable debugging on a channel
core set {debug|verbose} Set level of debug/verbose chattiness
core show applications [like|d Shows registered dialplan applications
core show application Describe a specific dialplan application
core show calls [uptime] Display information on calls
core show channels [concise|ve Display information on channels
core show channel Display information on a specific channel
core show channeltypes List available channel types
core show channeltype Give more details on that channel type
core show codecs [audio|video| Displays a list of codecs
core show codec Shows a specific codec
core show config mappings Display config mappings (file names to config engines)
core show file formats Displays file formats
core show file version [like] List versions of files used to build Asterisk
core show functions [like] Shows registered dialplan functions
core show function Describe a specific dialplan function
core show help Display help list, or specific help on a command
core show hints Show dialplan hints
core show hint Show dialplan hint
core show image formats Displays image formats
core show license Show the license(s) for this copy of Asterisk
core show profile Display profiling info
core show settings Show some core settings
core show switches Show alternative switches
core show sysinfo Show System Information
core show taskprocessors List instantiated task processors and statistics
core show threads Show running threads
core show translation Display translation matrix
core show uptime [seconds] Show uptime information
core show version Display version info
core show warranty Show the warranty (if any) for this copy of Asterisk
core stop gracefully Gracefully shut down Asterisk
core stop now Shut down Asterisk immediately
core stop when convenient Shut down Asterisk at empty call volume
core waitfullybooted Wait for Asterisk to be fully booted
data get Data API get
data show providers Show data providers
database del Removes database key/value
database deltree Removes database subfamily/values
database get Gets database value
database put Adds/updates database value
database query Run a user-specified query on the astdb
database show Shows database contents
database showkey Shows database contents
devstate change Change a custom device state
devstate list List currently known custom device states
dialplan add extension Add new extension into context
dialplan add ignorepat Add new ignore pattern
dialplan add include Include context in other context
dialplan debug Show fast extension pattern matching data structures
dialplan reload Reload extensions and *only* extensions
dialplan remove extension Remove a specified extension
dialplan remove ignorepat Remove ignore pattern from context
dialplan remove include Remove a specified include from context
dialplan save Save current dialplan into a file
dialplan set chanvar Set a channel variable
dialplan set extenpatternmatch Use the Old extension pattern matching algorithm.
dialplan set extenpatternmatch Use the New extension pattern matching algorithm.
dialplan set global Set global dialplan variable
dialplan show chanvar Show channel variables
dialplan show globals Show global dialplan variables
dialplan show Show dialplan
dnsmgr refresh Performs an immediate refresh
dnsmgr reload Reloads the DNS manager configuration
dnsmgr status Display the DNS manager status
event dump cache Dump the internal event cache (for debugging)
fax set debug {on|off} Enable/Disable FAX debugging on new FAX sessions
fax show capabilities Show the capabilities of the registered FAX technology modules
fax show session Show the status of the named FAX sessions
fax show sessions Show the current FAX sessions
fax show settings Show the global settings and defaults of both the FAX core and technology modules
fax show stats Summarize FAX session history
fax show version Show versions of FAX For Asterisk components
features reload Reloads configured features
features show Lists configured features
file convert Convert audio file
group show channels Display active channels with group(s)
hangup request <no description available>
help <no description available>
http show status Display HTTP server status
iax2 provision Provision an IAX device
iax2 prune realtime Prune a cached realtime lookup
iax2 reload Reload IAX configuration
iax2 set debug {on|off|peer} Enable/Disable IAX debugging
iax2 set debug jb {on|off} Enable/Disable IAX jitterbuffer debugging
iax2 set debug trunk {on|off} Enable/Disable IAX trunk debugging
iax2 set mtu Set the IAX systemwide trunking MTU
iax2 show cache Display IAX cached dialplan
iax2 show callnumber usage Show current entries in IP call number limit table
iax2 show channels List active IAX channels
iax2 show firmware List available IAX firmware
iax2 show netstats List active IAX channel netstats
iax2 show peer Show details on specific IAX peer
iax2 show peers List defined IAX peers
iax2 show provisioning Display iax provisioning
iax2 show registry Display IAX registration status
iax2 show stats Display IAX statistics
iax2 show threads Display IAX helper thread info
iax2 show users [like] List defined IAX users
iax2 test losspct Set IAX2 incoming frame loss percentage
iax2 unregister Unregister (force expiration) an IAX2 peer from the registry
indication add Add the given indication to the country
indication remove Remove the given indication from the country
indication show Display a list of all countries/indications
local show channels List status of local channels
logger mute Toggle logging output to a console
logger reload Reopens the log files
logger rotate Rotates and reopens the log files
logger set level {DEBUG|NOTICE Enables/Disables a specific logging level for this console
logger show channels List configured log channels
manager reload Reload manager configurations
manager set debug [on|off] Show, enable, disable debugging of the manager code
manager show command Show a manager interface command
manager show commands List manager interface commands
manager show connected List connected manager interface users
manager show eventq List manager interface queued events
manager show settings Show manager global settings
manager show users List configured manager users
manager show user Display information on a specific manager user
mgcp audit endpoint Audit specified MGCP endpoint
mgcp reload Reload MGCP configuration
mgcp set debug {on|off} Enable/Disable MGCP debugging
mgcp show endpoints List defined MGCP endpoints
minivm list accounts List defined mini-voicemail boxes
minivm list templates List message templates
minivm list zones List zone message formats
minivm reload Reload Mini-voicemail configuration
minivm show settings Show mini-voicemail general settings
minivm show stats Show some mini-voicemail statistics
mixmonitor {start|stop} Execute a MixMonitor command
module load Load a module by name
module reload Reload configuration for a module
module show [like] List modules and info
module unload Unload a module by name
moh reload Reload MusicOnHold
moh show classes List MusicOnHold classes
moh show files List MusicOnHold file-based classes
no debug channel Disable debugging on channel(s)
originate <no description available>
parkedcalls show List currently parked calls
phoneprov show routes Show registered phoneprov http routes
pri intense debug span <no description available>
queue add member Add a channel to a specified queue
queue reload {parameters|membe Reload queues, members, queue rules, or parameters
queue remove member Removes a channel from a specified queue
queue reset stats Reset statistics for a queue
queue set penalty Set penalty for a channel of a specified queue
queue show Show status of a specified queue
queue {pause|unpause} member Pause or unpause a queue member
queue show rules Show the rules defined in queuerules.conf
realtime destroy Delete a row from a RealTime database
realtime load Used to print out RealTime variables.
realtime store Store a new row into a RealTime database
realtime update Used to update RealTime variables.
realtime update2 Used to test the RealTime update2 method
reload <no description available>
rtcp set debug {on|off|ip} Enable/Disable RTCP debugging
rtcp set stats {on|off} Enable/Disable RTCP stats
rtp set debug {on|off|ip} Enable/Disable RTP debugging
say load [new|old] Set or show the say mode
sip notify Send a notify packet to a SIP peer
sip prune realtime [peer|all] Prune cached Realtime users/peers
sip qualify peer Send an OPTIONS packet to a peer
sip reload Reload SIP configuration
sip set debug {on|off|ip|peer} Enable/Disable SIP debugging
sip set history {on|off} Enable/Disable SIP history
sip show {channels|subscriptio List active SIP channels or subscriptions
sip show channelstats List statistics for active SIP channels
sip show channel Show detailed SIP channel info
sip show domains List our local SIP domains
sip show history Show SIP dialog history
sip show inuse List all inuse/limits
sip show mwi Show MWI subscriptions
sip show objects List all SIP object allocations
sip show peers List defined SIP peers
sip show peer Show details on specific SIP peer
sip show registry List SIP registration status
sip show sched Present a report on the status of the scheduler queue
sip show settings Show SIP global settings
sip show tcp List TCP Connections
sip show users List defined SIP users
sip show user Show details on specific SIP user
sip unregister Unregister (force expiration) a SIP peer from the registry
skinny reload Reload Skinny config
skinny reset Reset Skinny device(s)
skinny set debug {off|on|packe Enable/Disable Skinny debugging
skinny show devices List defined Skinny devices
skinny show device List Skinny device information
skinny show lines [verbose] List defined Skinny lines per device
skinny show line List Skinny line information
skinny show settings List global Skinny settings
stun set debug {on|off} Enable/Disable STUN debugging
timing test Run a timing test
udptl set debug {on|off|ip} Enable/Disable UDPTL debugging
ulimit Set or show process resource limits
unistim reload Reload UNISTIM configuration
unistim send packet Send packet (for reverse engineering)
unistim set debug {on|off} Toggle UNITSTIM debugging
unistim show info Show UNISTIM info
voicemail reload Reload voicemail configuration
voicemail show users List defined voicemail boxes
voicemail show zones List zone message formats
Connected to Asterisk 1.8.25.0 currently running on nas-D5-E1-96 (pid = 7112)
nas-D5-E1-96*CLI> help
database deltree Removes database keytree/values
skinny set debug {off|on} Enable/Disable Skinny debugging
Asterisk 11.7.0 version contains below things.
Connected to Asterisk 11.7.0 currently running on nas-07-13-34 (pid = 3011)
acl show Show a named ACL or list all named ACLs
core show hanguphandlers all Show hangup handlers of all channels
core show hanguphandlers Show hangup handlers of a specified channel
dialplan remove context Remove a specified context
mixmonitor {start|stop|list} Execute a MixMonitor command
presencestate change Change a custom presence state
presencestate list List currently know custom presence states
queue set ringinuse Set ringinuse for a channel of a specified queue
stun show status Show STUN servers and statuses
udptl show config Show UDPTL config options
unistim show devices Show UNISTIM devices
Kedar
Kedar
- Aug 16, 2018Retired_Member
- Jul 21, 2021Retired_Member
