chopsywa
Jan 31, 2014Aspirant
Asterisk app missing critical lib module
Hi guys The Asterisk app installs fine, but the SIP functionality is non-existent as it appears the chan-sip module is missing from the package. I have re installed in case it was an install gli...
kedar
Feb 20, 2014Aspirant
Hi Mark
Can you please go through the CLI commands available in 10.0.0 that I mentioned. If you think you are getting what desired than I will package that version and release.
Kedar
Kedar
- Aug 16, 2018Retired_Member
- Jul 21, 2021Retired_Member
