chopsywa
Jan 31, 2014Aspirant
Asterisk app missing critical lib module
Hi guys The Asterisk app installs fine, but the SIP functionality is non-existent as it appears the chan-sip module is missing from the package. I have re installed in case it was an install gli...
kedar
Feb 21, 2014Aspirant
Hi Mark
I have created deb package containing version 10.0.0 (have chan_sip module) and installed in 115.111.157.71. admin / password.
Can you please check whether the required modules are available. Then I can submit it for Netgear QA. If you can not test it unless comes through an official procedure then please let me know. As I do not want you and others to go through the same process again and again due to missing of some functionality or other so thought of getting some level of verification before submitting.
kedar
kedar
- Aug 16, 2018Retired_Member
- Jul 21, 2021Retired_Member
