chopsywa
Jan 31, 2014Aspirant
Asterisk app missing critical lib module
Hi guys The Asterisk app installs fine, but the SIP functionality is non-existent as it appears the chan-sip module is missing from the package. I have re installed in case it was an install gli...
chopsywa
Mar 07, 2014Aspirant
Great I will install it and let you know how it goes. Is there any way to install this package on the 4.x versions of Readynas?
Thanks Kedar.
Thanks Kedar.
- Aug 16, 2018Retired_Member
- Jul 21, 2021Retired_Member
