Digital999
Jun 20, 2020Luminary
Camera Survillance Software
We have a variety of ReadyNAS systems. We have several Amcrest cameras that we are trying to connect to the ReadyNAS system via FTP protocol. Once completed there will be a widespread rollout of...
JohnCM_S
Jun 24, 2020NETGEAR Employee Retired
Hi Digital999,
Currently, we do not have any surveillance software that will work on our NAS units. We have before the ReadyNAS Surveillance and the Milestone Arcus but both are already in End of Service. (https://community.netgear.com/t5/ReadyNAS-Storage-Apps-Current/ReadyNAS-Surveillance-and-Milestone-Apps-End-of-Service/m-p/1721630)
- SandsharkJun 25, 2020Sensei
There are a number of Linux surveillance programs that could be installed on a ReadyNAS, but not as a app. Google is your friend here. You'd need to go to SSH to install, and perhpas to do some management. Not all of them are designed to be installed or managed headless, though. It is a shame that Netgear has still not implemented Docker as an official part of the OS. Running these containerized, especially for the evaluation part, would be best.
Personally, I run Blue Iris on a PC and use the NAS as archival backup. Up untill I moved to rack mount NAS and decided to get a wizz-bang rack mount PC for all my applications and virtual machines, I used a very basic, older computer (Core2 Quad) to do that. Blue Iris runs on Windows. If I had gone with Linux on the PC, it probably would have run on an even lesser machine using one of the (many free) Linux options for survelillance.
- yobanJun 25, 2020Apprentice
Hi there
I run iVideon (www.ivideon.com) on my RN314 within a docker container which works very well. It could also be possible to install natively too with a bit of work.
- Digital999Jun 26, 2020Luminary
Thanks for those who replied.
We use our ReadyNAS systems for production related purposes -- i.e. no development and management of environment only.
I just want to purchase a solution and not get into development mode.
Seems like a market for Netgear but they will need to decide.
